Can't install assets
   7564   1   1
Novice Houdini user with an active Indie subscription
This may be a License administrator issue.
I can launch and run Houdini (Windows 10) no problem via a shortcut on my desktop.
However, when trying to install any Orbolt asset the Orbolt install executable launches my license administrator.
My license administrator tells me that I cannot modify license from this machine and the install quits.
Can anyone help?
It may simply be reporting the truth. Each asset on Orbolt has a required license. An Indie license may not be enough for the asset you have chosen. Contact the asset developer or re-read the license requirement for the asset on Orbolt.
Have you tried simply copying the .otl file directly into your Store/Assets folder? Typically found under My Documents/ Houdini 15.x/…
Once copied to the folder you can reference it into your scene via File/Import/Houdini Digital Asset.
Try something free like the Equalizer from SideFX, it has a completely open license.
Using Houdini Indie 20.5
nVidia 3060RTX 12BG RAM.
