VDB Combine through noise map?
   5357   2   1
Hi there,
I'd like to combine 2 vdbs (one eroded, the other dilated) through a 3D noise map acting as alpha mask.
Do you know what could be a suitable workflow?
screenshot for reference:
Thanks for any help!
Edited by Andr1 - Aug. 10, 2016 05:48:26
Assuming you have level sets, try linear interpolation with a volume wrangle? (see attached)
the only trick is that volume wrangle only iterates over set voxels, so you may need to resize your narrow band to activate a wider topology (to account for the data in the second input).
Edited by jbudsberg - Aug. 31, 2016 12:29:05
Hello and thanks for the helpful tip, jbudsberg!
(and for taking some time to produce the screenshot)
I've never used volumeVop and volumeWrangle. Nice to learn something new (-:
cheers
