Custom VOP Output Strange Behaviour
   2192   2   1
Hi all,
I have created a custom VOP with a colour output. However, when I multiply this output with another colour inside a VOP network the result is much darker than it should be and I can see no reason for this happening.
Take a look inside the shop network > cl_test. Change the input on switch1, this will render the custom VOP output (called ChanLum1), then the multiplication mask (from the trace_inside network part), then the multiplication of the two. You will see that the multiplication is not correct.
I'm at a loss here, I checked that all the input types are ‘color’.
I think you forgot to upload your hip file ^^
Oops
Shading_Tests.hipnc (657.0 KB)
