Less lengthy version of opinputpath
   5953   5   1
I find myself extremely often having to type the following expression:
opinputpath(“.”, 0)
It's very frustrating to me that this is such a long expression when I need it all the time. I might be doing something wrong, but I don't think so. Is there an easier way of getting that first input on the current node?
Can SideFX not simply add a few additional methods? You would still have the original:
opinputpath(string path, int index)
// Doing all the magic here
And then two much easier ones, for example:
opin(int index)
opinputpath(“.”, index);
opin()
opin(0);
sumtime you can replace it by using geoself() or just 0 for the first input in wrangle node…
v@P2=point(geoself(),“P”,@ptnum+1);
or
v@P2=point(0,“P”,@ptnum+1);
if you give me a sample scene maybe i can give you a better answer…
patar
Yes, I know, Wrangle nodes are not the problem. In fact, this is how short I would want it to be.
I don't have an example scene at hand, but right away I can think of a million examples.
I want to put the current mesh onto the ground plane
-bbox(opinputpath(“.”, 0), D_YMIN)
I have a curve and need it's length
arclen(opinputpath(“.”, 0), 0, 0, 1)
I want to query a detail attribute
detail(opinputpath(“.”, 0), “attribute”, 0)
I want to know how many points I'm working with
npoints(opinputpath(“.”, 0))
It drives me crazy, seriously :-)
It helps your mind Chris
Why not write a HScript \ Python script where you can run and get prompt for specific attributes so you can do it faster
【T】【C】【S】
works every time by replacing “opinputpath(“.”, 0)” with “0”
opinputSample.hip (135.0 KB)
