Hi everyone
I've got a slight issue and unsure where i'm going wrong.
I'm right clicking a null and going into “edit parameter interface” to create a float.
(can be seen in the image) i'm setting the name to “trans” (an attribute i created, also in the image)
when looking at the geometry spreadsheet the value of “trans” does not change. Trans is a detail attribute.
I'm using trans to control an objects transform. I know i can link the slider to the transform node but for the purposes i need it for, it needs to be an attribute.
the null controlling the attribute is at the bottom of the network.
Slider controlling attribute not working
4296 2 0-
- wjm
- 39 posts
- Anti-Distinctlyminty
- 271 posts
You have nothing that tells the detail attribute that it should take the value you provided with the slider. Currently they are two unrelated things: the detail attribute, and a slider control.
Try putting down a detail wrangle node and using it to set the value of your attribute to that of the slider
If the Null is on the same levels as the wrangle node.
f@trans = ch("../Null/trans")
- blackpixel
- 182 posts
