Hi All!
I'm trying to find a way of getting useful infos about a pyro sym I'm doing and then exporting to vdb files. I need to know which is the density/heat/temperature min and max values in order to remap those values correctly outside of houdini. any idea?
get VDB info
4654 2 0-
- nicoladanese
- 8 posts
- blackpixel
- 182 posts
- nicoladanese
- 8 posts
Hi Mariusz
thanks for your reply, meanwhile I was looking around and found this solution as well (maybe is the same you suggested)
http://forums.odforce.net/topic/12234-how-to-get-the-min-and-max-values-of-a-volume/ [forums.odforce.net]
reg the vdb, you're right you cannot plug vdb straight but you can convert them and read the data
