GLSL point scale attribute
2311
2
0
- ripclaw
- 96 posts
I've been playing with GLSL shaders but so far I haven't worked out how to access things like point scale. Are there any samples around somewhere?
- malexander
- 5287 posts
You can look at houdini/glsl/particle/GL32/disc.prog (which references the .vert, .frag, and sprite.geom). You basically want:
in your vertex shader to grab pscale. Houdini attributes are matched to GLSL shaders by name.
- monomind
- 22 posts
Very similar question I'm dealing with! This is an old topic but felt like bumping here, an example would be perfect!
