I am trying to create an openGL rendering (PGN image) with a white background. Currently I am getting black in the areas that are transparent.
I tried to go to the openGL node and set Scene>Background Image to a white image, same pixel resolution as the rendering. But it seems to have no effect. When I click render (Output image is ‘ip’), i still don't get a white background.
In MPlay:
I tried to go to Windows>Display Options>Background Colour to white. Then I saved the PNG image. But no effect, still a black background.
I tried to go to Windows>Display Options>Filename to a white image, same pixel resolution. Then I saved the PNG image. But no effect, still a black background.
Any suggestions? How to get a white background?
OpenGL rendering with white background
3858 1 0-
- phtj
- 224 posts
- wlvl_yfx
- 14 posts
late to the party but..
one workaround is referencing a white color from COP network in the Scene / Background Image parameter (bgimage)
op:/obj/ropnet1/cop2net1/OUT
see file attached
this trick will work only for simple background (ie. one color).
If you add cops operations it will become very slow.
see file attached
