If i change my view to all 4 viewports and create some geometry i cant see anything in the persp view. I am just wondering can i frame selected objects in views using a keyboard shortcut.
frame object in a viewport
29012 7 2-
- grimmus
- 3 posts
- Simon
- 2199 posts
- uniqueloginname
- 330 posts
- Simon
- 2199 posts
- ben simons
- 387 posts
SimonSpace_bar + “g” works for me.
Try “F” for frame
or “H” for home
Though, somedays, if I want to super turbo framing I hold down space and shift and f and g and h, and press really hard. :wink:
To see the Safe Area guides, press space+d and there's a “safe area” button down the bottom of the Guides & Markers panel.
cheers,
ben.
''You're always doing this: reducing it to science. Why can't it be real?'' – Jackie Tyler
- Simon
- 2199 posts
Sorry should have said
“f” is for frame - ie don't rotate the view doesn't need the shift key
“h” is for home - ie align with axis - again does need the shift key
and I forgot “g” which does the same as “h” not sure why there are two keys for the same thing.
- edward
- 8122 posts
- Simon
- 2199 posts
