Cannot get material SOP to work on points
   2461   4   1
Hi all,
I have a bunch of points, which I'm trying to apply a material to. However, if I use a material SOP it just does not work. I have to apply the material at the obj level. Is this normal or am I missing something? If this is normal behavior, then why not allow materials to be assigned to points at the SOP level?
I've attached a very simple scene showing this.
Points_Material.hipnc (205.1 KB)
so what happens when you delete your light?
Yes…it turns out that it's handy if there's a light in the scene That's what i get for working late at night.
But one thing that is odd - if you apply the material on torus_object1 > Render > Material, then it does show up as a solid colour.
Is there a reason that these two material assignments act differently?
Not sure - could be a bug - can you submit it please. Thx!
Will do!
Submitted, ID=80976
Edited by Anti-Distinctlyminty - Feb. 27, 2017 14:28:01
