I have several curves which I resample and turn on Curve U Attr and I like to group the points which are @curveu == 0. But in the group node if I toggle Expression on at the Base Group field only one point shows active. Expanding the String Value shows 1 and not all the points which are @curveu == 0.
If I visualize the curveu attr than I should get point ids like 0 27 54 81 108 135 162 189 …
Added hip file.
Thanks for the help.
Stephan
How to group points from several curves in Houdini 16?
3796 3 1-
- osterburg
- 2 posts
- neil_math_comp
- 1743 posts
The “Base Group” field is a string parameter that's evaluated only once. In your HIP file, it's set to be evaluated as an HScript expression.
If you remove the expression and just put in the string
@curveu isn't defined in HScript, so it seems to be defaulting to 0. 0 == 0 is true, so it evaluates to 1. That gets converted to the string 1 for the parameter, so Base Group is then just 1.If you remove the expression and just put in the string
@curveu==0, (see attached), it seems to work as expected, because the group parsing identifies @curveu==0 as something that it needs to evaluate as a group. This should work the same in other Group parameters as well. Hopefully that helps clear up the confusion!
- osterburg
- 2 posts
- dyei
- 28 posts
