RFE: display control hotkeys
3537
3
1
lisux
Nov. 18, 2005 1:50 p.m.
Hi SESI, again
Well it could be great to have the possibility to set hotkeys to the display controls buttons in the 3d viewer pane, for example to toggle point or uv display on the fly using a key.
For the halo viewer could be interesting too.
Un saludo Best Regards Pablo Giménez
stevenong
Nov. 18, 2005 2:38 p.m.
Hi Pablo, While waiting for the RFE, you can set up Function key aliases to do what you want for the 3D viewport. To turn points on or off alias F1 viewdisplay -N all m on * alias F2 viewdisplay -N all m off * Note: The asterisk (*) sets the display option for all views. Please do “help viewdisplay” for all display options. In addition, the Halo viewer has hotkeys most of the buttons. Which is the display option you want a hotkey for? I hope the above helps! Cheers! steven
lisux
Nov. 21, 2005 3:58 a.m.
Thanks Steven, very useful. Like in the problem with the safe area in COPs viewer i think that shortcuts are needed here. But at the moment your advices solves the problem.
lisux
Dec. 29, 2005 8:42 a.m.
stevenong Hi Pablo, While waiting for the RFE, you can set up Function key aliases to do what you want for the 3D viewport. To turn points on or off alias F1 viewdisplay -N all m on * alias F2 viewdisplay -N all m off * Note: The asterisk (*) sets the display option for all views. Please do “help viewdisplay” for all display options. stevenIt is possible to bind another keys, appart from the function keys, to a sequence of commands using the alias statement or something else?
