Foam, Spray and Bubble shading
   2633   1   1
Hi all, I want to know what are the most efficient way to render Foam, Spray and Bubble. I have tried as point with Mantra_Surface_shader and as volume with billowy_smoke_shader. Is there anyone using different Technic?
Edited by manishfx - May 16, 2017 07:08:51
Manish Sharma
FX TD
I am usually using Point method too ,You can take perfect result when you have million of particles with crazy small pscale and also adding motion blur in rendering
Rabiee.Sadjad@Gmail.Com
