Debian ATI9200 libGL.so.1
   4826   5   1
Just installed Houdini on My Debian system.
I have an ATI9200/9250 card, I haven't installed drivers for this card, any tips on doing this under Debian. I downloaded drivers from ATI, but they didn't install successfully , do I need to compile them for my system???
When I start Houdini it can't find libGL.so.1 is this because I haven't installed the card drivers??? I can't find it this package in Debian Testing repository.
Any tips greatly appreciated.
Yeah, usually the video driver will provide the GL library (for nvidia anyway).
The xlibmesa-gl provides the software version of the GL library.
Can you give more information as to why the ATI drivers didn't install?
I got around that problem by dynamically linking to libGL.so.1.2
Why the ATI drivers don't install, not sure yet, if I download the .rpm and use alien to create a .deb I get dependency problems, If I download ATI's custom installer utility, this just doesn't fire up, I get “Permission Denied” even though I'm trying to run it as root.
Arghhhhh, must resist tearing last few strands of hair from scalp.
Now that I got Houdini running, I have another problem with the Licence server. I'll post that next.
Linux Love Hate Love Hate Hate!
redg
I'm unsure whether I should even suggest this, mainly because you're probably trying to run the wrong thing (as root). However! Here goes. Even root can get a “Permission Denied” if the file does not have its' execute flags set. Normally, you would expect a file which is meant to be executed and is distributed by a company to already have these flags set - if it is indeed meant to be run. Say the file is called fred. Then do a “/bin/ls -l fred” and have a look at the flags. Chances are they look like this -rw-r–r– To make it executable, run this: (don't type the “#”!)
# /bin/ls -l fred
# chmod +x fred
# /bin/ls -l fred
You should see “x” flags there now. This will let root execute it. Permission denied is a fairly misleading error when the problem is missing execute flags.
Keep in mind, if this file is NOT meant to be executed afterall, bad things™ could happen..
With Linux now everyone's a sys-admin… And this is good because..?
regards,
ben
''You're always doing this: reducing it to science. Why can't it be real?'' – Jackie Tyler
Thanks Ben,
Still adjust to using Linux, I guess I just assumed that an executable downloaded from ATI would be executable, it wasn't, thanks for the tip.
redg
Thanks Ben,
Maybe it is not a executable because the installer is a script, the nvidia drivers use the same format.
Anyway if this is the case, notmally you have a .sh file, you can use the sh command to launch a script that is not a exectable file:
sh installer.sh
Jeje yeah this is good!
Un saludo
Best Regards
Pablo Giménez
