$YMAX not working
   5118   10   1
I can't find an answer to this anywhere. I can't use $BBY, $YMAX, $ZMIN, etc. It gives me this error:
Unable to evaluate expression (
SyntaxError: ('invalid syntax', ('', 1, 1, ‘$YMAX’))
(/obj/grid1/transform2/ty)).
Can you attach a HIP file where this is happening?
ndickson
Yep! I just placed a box in the scene with a transform.
Edited by AustinDrozin - May 28, 2017 21:42:59
YMAXProblem.hipnc (51.1 KB)
I am still having this problem sadly.
I get a load warning when opening that HIP file, and it doesn't load in an expression for /obj/grid1/transform2/ty . What expression did you have there? It works if I put $YMAX there.
ndickson
Yeah I just put $YMAX and it gives me that error I listed in the original post.
$YMAX is HScript not Python. Set it in the top right of the parameter panel
Edited by anon_user_37409885 - May 30, 2017 19:18:03
aRtey
Is it possible to switch in the middle of working? Because I tried that before but it didn't remove the error. Now I try $YMAX after setting both nodes to HScript before hand, and it works. I set it back to Python and it still works…
I have no idea how this is happening..
No, it does not work properly. In a python, you can not just write $YMAX and get the result of a local variable. For these purposes, there is a function called hou.lvar(“YMAX”) which will return any local variable for this node.
hou.alex.get
Using both versions with both HScript and Python gave me an error. Not every time though. If I start a new project and do it again it'll work sometimes. It's not consistent.
Just sounds like a non-standard workflow that we aren't familiar with - perhaps post a screen recording or exact steps so we can see what's happening.
