Pulling apart a voronoi fracture
   2396   2   1
Basically I would like to fracture a cube and then grab a bunch of pieces on the left and right sides and then pull it apart and let the glue holding it together do stuff.
I've got the fracture and glue loaded into dops but I'm unclear how to grab a bunch of pieces on either side and pull it apart.
help?
I haven't test it but you can animate one or more pieces on both side pulling apart and import it into dop as an rbd packed animated static object. Then you keep the rest of the pieces as active objects and glued to the animated pieces.
If you look at one of the bullet masterclasses, Jeff has a series of files you can download that shows you how to deal with glue constraints in a variety of ways.
