constraint network for sub fractured pieces
   1789   0   0
I created a shatter that creates concave pieces, so I thought I'd do a voronoi fracture on sub-pieces. I've been trying to figure out a way to create a constrain network to hold the convex pieces of the original concave pieces together, but I can't figure it out. I tried to copy class attribute from connectivity sop of the original fracture use it as controlling attribute in cluster point node but that didn't work. Only way it kind of works is if I turn of name attribute from voronoi fracture/assemble node but then the inside edges are not connected properly.
Edited by uuLLFA - Oct. 9, 2017 00:16:12
