How to import ass file with Arnold in Houdini?
   10011   1   1
Hi! I am using Houdini 16.5.268 and HtoA 2.2.0. I tried to import the lighting ass file by arnold_procedural in Houdini, but it didn't show up in the viewport. Also I tried to render it, but it came out with Error that showing “Error Command Exit Code: 1”.
The ass file was working fine in Maya, and the Arnold render was working ok without Arnold_procedural node.
Am i doning something wrong? or there are other way to import lighting in HtoA?
Edited by ShuShu - Jan. 2, 2018 13:14:36
make sure you are using same versions of Arnold in both apps, then make sure you are pointing arnold rop to mtoa shaders.
https://support.solidangle.com/display/AFHUG/Sharing+.ass+Files+Between+Plugins [support.solidangle.com]
