i can't fix that the water leaks out through a glass
3278 3 1-
- wahir00
- 3 posts
- huey_yeng
- 69 posts
You need to give a thickness to the tube and also a decent VDB volume for collision. Other than that, you're pretty spot on with the network setup.
I attached a simple demo of my equivalent setup like yours. Do study it and compare the difference with your setup!
Edited by huey_yeng - March 26, 2018 12:51:01
- wahir00
- 3 posts
- wahir00
- 3 posts
added “vdb from polygons” between “subdivide” and “collision source”
and changed voxel size in “collision source”
and then set up to Static object>Collisions>RBD Solver>Volume>Mode “Volume Sample”, Division Method “By Size”, Proxy Volume “/obj/glass/VDB”
As a result, this glass could hardly the water leaks out through!
but another problem occurred. The level of water in the glass has gone down..;_;
