Hi
I have a foreach loop which loops through each polygon of the input geometry. Each polygon has an attribute called primnum. Inside the loop i'm trying to output a file for each iteration of the loop and use the primnum attribute as part of the filename. Is this the correct syntax?
filename.$primnum.bgeo.sc
I'm getting one file named filename..bgeo.sc
include an attribute value in a filename
2185 3 1-
- 3di2017
- 12 posts
- subscriptions
- 31 posts
- 3di2017
- 12 posts
- 3di2017
- 12 posts
