Rendering imported geo with renderman
   2112   1   1
Hello everyone!
Has anybody tried using renderman and custom geo imported into houdini?
for some reason only the imported stuff doesnt seem to work; geo that I created within houdini will render no problem using the same shaders.
The custom geo that imported does render in mantra though.
Im attaching screenshots of this different scenarios.
Are there any neccesary considerations for rendering alembic geo (or even obj imports) when using renderman in houdini?
If you have come across this issue do let me know,
If anybody is interested, I finally was able to fix it.
You have to go to the alembic geometry settings in the deepest node of the network and change the Load As to “Unpack Alembic Delayed Load Primitives”
