I've searched the forums and only found a single question related to this issue, so hopefully this isn't a FAQ…. How do you set up Softimage-style reference images in Houdini?
I know you press D and then can pick a background image, but the image doesn't remain stuck to the background grid the way it does in Softimage.
I saw someone on YouTube had a script that would create a grid based on an input image (Softimage has an addon called Imageplane that does this) but the person didn't release the script.
I also found the Navigator Python script, but that seems to only work with a scene camera, which is not what I'm looking for either.
So, is it possible to do Softimage style reference images in Houdini? Not a grid with a UV map. Just a background image that scales with the background grid.
I've finally got an excuse to move from Softimage to Houdini & I'm anxious to get started (I've gone back to grad school at nearly age 50…).
-Paul
SI style reference images?
3795 1 2-
- Paul Griswold
- 79 posts
- julca
- 271 posts
