Ever sence Houdini started issuing ‘…will expire soon’ messages, rendering has been on the fritz. Basically in a given session, after a while, Houdini will no longer render. Any attempt to get a test render fails, nothing happens. Mantra does not launch. Likewide trying to render with Ouputs also fails. Upon pressing of the Render button in the properties of Mantra tile, the ison of the tile turns to red play button and rendering does not happen. In both case, no messages are issued. Nothing happens.
What is going on?
Dave Rindner
Mantra no longer renders
15674 9 0-
- Dave_ah
- 436 posts
- stevenong
- 1634 posts
- Dave_ah
- 436 posts
Diagnostic Output:
If you are having licensing problems, please save this information and email it
to support@sidefx.com.
License Administrator output:
Generated on: Thu Aug 22 22:00:28 2002
Local host name: DAVID_RINDNER
Local server code: 75dbb081
Local ip address: 127.0.0.1
License server name: david_rindner
License server server code: 75dbb081
Server ip address: 127.0.0.1
License server is running: Yes
Has SERVER license: Yes
License server version: 5.5.36
May modify server from this machine: Yes
License Administrator version: 5.5.36
Http proxy host: (none)
Using standalong mode: Yes
Can retrieve http://license.sidefx.com/index.php: [license.sidefx.com] Yes
Installed licenses:
LicID Platform Product Ver Avail Expiry
081c4f86 Generic Houdini-Master-NonCommercial 5.5 1/1 27-aug-2002
5ce1423b Generic Render-NonCommercial 5.5 0/1 27-aug-2002
=== For some reason, this license is not valid ===
=== (Maybe machine names don't match?) ===
5ea58968 Generic Houdini-Halo-NonCommercial 5.5 1/1 27-aug-2002
sesictrl -i output:
—– SERVER david_rindner ——–
Lic 081c4f86: 1 “Houdini-Master-NonCommercial 5.5” Generic 27-aug-2002 +.+.+.+
1 licenses free
Lic 5ce1423b: 1 “Render-NonCommercial 5.5” Generic 27-aug-2002 +.+.+.+
274 by nowhere.com Aug 17 12:59
Lic 5ea58968: 1 “Houdini-Halo-NonCommercial 5.5” Generic 27-aug-2002 +.+.+.+
1 licenses free
hserver -l output:
Hostname: DAVID_RINDNER
Uptime: 9 days, 9:26:19
License Server: david_rindner
Server Version: sesinetd5.5.36
Version: Houdini5.5.36
ReadAccess: +.+.+.*
WriteAccess: +.+.+.*
164 of 767 Mb available
CPU Usage: 10% load
0 active tasks (1 slots)
Warning: david_rindner has keys which you will need to reactivate shortly
Key: 081c4f86 in 5 days
Key: 5ce1423b in 5 days
Key: 5ea58968 in 5 days
licenses file:
## Side Effects Software License File
# For license information, please contact:
# Side Effects Software Inc.
# 477 Richmond St. West, Suite 1001
# Toronto, Ontario, Canada
# M5V 3E7
# licensemanager@sidefx.com
# http://www.sidefx.com [sidefx.com]
# NOTE: This file may be modified by the licensee
# Key installed 00:00:14 07/27/02
SERVER david_rindner 75dbb081 \
266019c76af88cc1cca049f4d52d37a5a5716ff9b3af52
# Key installed 00:00:16 07/27/02
LICENSE Generic Render-NonCommercial 5.5 1 27-aug-2002 +.+.+.+ \
david_rindner 5ce1423b c8325eda7e8887c5916e0549fcd02c4c1e9724a33f94
# Key installed 00:00:18 07/27/02
LICENSE Generic Houdini-Master-NonCommercial 5.5 1 27-aug-2002 +.+.+.+ \
david_rindner 081c4f86 \
4aef5faa7ecaa8e9dff6d19c5569066085d742a59a1ed
# Key installed 03:36:04 07/27/02
LICENSE Generic Houdini-Halo-NonCommercial 5.5 1 27-aug-2002 +.+.+.+ \
david_rindner 5ea58968 \
e6d1efa865b769ad035b876525abe82d299a8af08d304
Installed licenses:
sesictrl -i output:
1 licenses free
1 licenses free
hserver -l output:
ReadAccess: +.+.+.*
CPU Usage: 10% load
licenses file:
# M5V 3E7
- stevenong
- 1634 posts
- stevenong
- 1634 posts
Hi David,
It seems a render didn't quit properly hence Houdini can't render.
Please try the following:
Bring up the Windows Task Manager (Ctrl-Shift-Esc or Right-click on the Taskbar and select Task Manager from the pop-up) and click on the Processes Tab. Look for mantra.exe, select it and click on the "End Process" button.
If there are more than one mantra.exe and clicking on "End Process" doesn't work or gives you an error, please select the next mantra.exe and click "End Process" again.
Once done, you can try rendering with Houdini.
If all else fails or if you don't want to do any of the above, please reboot your machine.
I hope the above helps!
Cheers!
steven
Cheers!
steven
- Dave_ah
- 436 posts
- stevenong
- 1634 posts
- Dave_ah
- 436 posts
I am sorry. I get no rendering whatsoever, from any project, at all. I LMB the render button in viewport and nothing. A Mantra output tile, turns red upon press of Render button. And there is no Mantra.exe, now, in Task Manager. Its like the rendering portion seems to have completely been turned off. I get no error messages anywhere, simply nothing happens.
Rebooting , the app or the machine, doesn't fix anything.
Perhaps its has something to do with re-authorising Apprentice, but I can't do that either. As the codes I get from SideFX are rejected by licence manager.
Dave Rindner
Dave Rindner
- stevenong
- 1634 posts
- Dave_ah
- 436 posts
OK, as per request, here is the latest output from licence diagnostics. I would like to know, when and how can I re-authorize Apprentice. Its telling me that I have three days left , yet it keeps rejecting the codes. Why is this proccess so damn complicated?
Dave Rindner
Diagnostic Output:
Generated on: Sat Aug 24 14:45:21 2002
Installed licenses:
5ce1423b Generic Render-NonCommercial 5.5 1/1 27-aug-2002
sesictrl -i output:
1 licenses free
1 licenses free
1 licenses free
hserver -l output:
Uptime: 11 days, 2:11:13
ReadAccess: +.+.+.*
157 of 767 Mb available
CPU Usage: 23% load
Key: 081c4f86 in 3 days
Key: 5ce1423b in 3 days
Key: 5ea58968 in 3 days
licenses file:
# M5V 3E7
Dave Rindner
Diagnostic Output:
Installed licenses:
sesictrl -i output:
1 licenses free
1 licenses free
1 licenses free
hserver -l output:
ReadAccess: +.+.+.*
CPU Usage: 23% load
licenses file:
# M5V 3E7
