Hi! I'm trying to set up HQueue. The server/client is a Fedora 28 box and the client is a Centos 7 box. My shared folder is on a NAS. I can see the computers by their hostnames both from each other and from themselves.
I get as far as submitting to the farm, tracker spinning up but then nothing. When I go to the tracker web page it's blank except for the table headers. The client sees the file, loads it but that's where it stops - like just sits at 0%.
I turned off all firewalls, selinux… everything I can think of. Moved shared folders, checked permissions, etc. The file renders fine if I load it manually so thats not it. The odd part is that it was working briefly, then I tried adding a 3rd machine (A mac) and it seems thats when the trouble started. I removed it just in cases.
Anyone else have this issue?
Attached a screenshot and log - removed because of show info in the filename. I'll post it without names if its needed.
HQueue Sim Tracker Problems
1934 1 1-
- Anthony Morrelle
- 39 posts
- Anthony Morrelle
- 39 posts
