Pre-render script to turn off camera background images
   3005   5   0
I've been trying to find something on this, I'd like to Mantra ROPS to turn off background images prior to render any help is much preeesh
I put in an RFE years ago that would make the background image for the sceneview independent of the ‘background image’ for mantra. The two are completely unrelated and having one parameter for both is unsatisfactory.
Have you tried a pre-render script that sets the ‘enable background’ checkbox to off for the render camera?
something like:
opparm `chsop('camera')` vm_bgenable ( 0 )
Edited by jsmack - Aug. 28, 2018 18:10:51
Cool, just checked this one and Viewport and Mantra BG are separate already - use the Display Options/Background Camera tab - ‘Display Background Image’ and a file path and disenable the ‘Enable Background Image’ on the Camera.
fuos
The camera tab is disabled for me when I check. The only way I can find to place the image as a background for the camera is with the parm on the camera. You can still uncheck ‘enable background image’ on the camera, as the image shows up in the viewer even with it disabled.
Try locking the camera the perspective view to the camera - lock icon -viewport rhs. The camera tab should then enable. Convoluted - yes!
That works great, thanks!
