For each connected piece question
   3745   2   0
I have a Polygon tube and I set the connectivity to rows. I want to rotate each row differently in Y, so I put it in a for each connected piece web, and create a transform, with fit01(rand(@class),0,360) in Y. @class was made with the connectivity node that came with the for each loop and gives each piece its own number. However it rotates every piece the same amount. Is there something basic I am not understanding? Thank you for your time.
hey use this expression
fit01(rand(prim(0, 0, “class”, 0)),0,360)
instead of @class that would work in a primitive wrangle, you need to use the prim() expression to retrieve to attribute “class”.
Andr
Thanks! That worked.
