Render a z depth map with normalized values as a jpg
   1980   2   2
I'm trying to render a depth map but with normalised values and I need it as a jpg (or png).
I've set my mantra node to have an extra image plane with a VEX value of Pz and a Float VEX Type. I've also changed the “Different File” extension to be “.jpg” since it seems that's how Houdini is deciding on the file type. It works fine.
When I export as a jpg and view it in Image Viewer, any value greater than 1 is clipped off at 1. So I can't normalised it in code since the data is lost.
I'm running it from a little python server so I need it to render to file.
Edited by dustinsilk - Dec. 6, 2018 11:44:07
May be you could use a kind of custom normalized Depth in AOV
like this :
untitled.hiplc (1.4 MB)
Benjamin you genious!!!! Thanks a lot!
