How do I Triangulate Cylinder Cap?
   4199   8   1
I am thinking about moving away from Maya to Houdini and am trying out the apprentice version. I am going to model something basic first and have got stuck straight away
I have created a tube, Changed it to a Polygon type, enabled End Caps but the end caps aren't showing any polys so currently its an engon. In Maya when you first create a Cylinder it shows the caps have each edge vertex going to a single point in the centre of the cap if that makes sense?
How can i do this please?
Thanks for your help!
Joe
Edited by joedickenson - Jan. 21, 2019 12:33:05
I think the right word would be Triangulate the cap. I have tried using Polyfill then switch it to poly triangle but I can't then put an edge loop around it
Hello
You can use a polyfill node set to triangle fan mode and un checking deform patch to get what you want
Benjamin Lemoine
Hello
Hi Thanks alot for your reply
I have tried this and but I can't seem to put an edge loop on the cap (Probably should of said that in my first post sorry!)
like this ?
(it's an option on the polyfill)
Benjamin Lemoine
like this ?
Ah thanks so you much! Knew it would be right infront of me haha
Can I add more than one loop?
Thanks for your help really appreciate it
You could use the polysplit node set on edge loop (but it's only working on quad face , so you will need the first loop created by the polyfill)
Maybe the best , to have something even with the edge loop would be to use a polyextrude with scale 0 with some division
there's allway a lot a way of doing things in Houdini , that's why it's fun ;-)
Benjamin Lemoine
Thanks alot thats really helpfull
