If expression in font sop
   3101   2   1
I'm quite new to houdini and get around using “if” expression in font sop.
I want to change the value (L or R) in font SOP by the value(hand: 0 or 1) in controller.
This is what I write, but it could not work.
if(`chs(“../CONTROLLER/hand”)` == 1){`L`}
Is it possible to use “if” in font SOP?
if you're using hscript expressions and you want to return a string from an if statement, use ifs() instead.
additionally, you're using VEX syntax for that if() statement. you can't use VEX in a parameter expression like that. the expression version looks like this:
ifs(condition, “string if true”, “string if false”)
Edited by toadstorm - Feb. 5, 2019 13:52:49
Thank you, toadstorm.
I can solve the problem.
The correct code is
`ifs(ch(“../CONTROLLER/hand”)==0,“L”,“R”)`
