Hello, first post here.
I'm trying to do something that seems simple but I just cannot figure it out.
I'd like to take a piece of geometry and copy it to points, and randomize scale in each direction to give it some variation. I've tried using rand() a number of different ways, in a for-each loop, but any time I apply a random change to scale in X, Y and Z each copy ends up looking identical.
It's probably dead easy but I'm stuck!
Thanks in advance for any help.
Copy to Points with random scale in each direction
19311 2 0-
- bootshank
- 1 posts
- skoora
- 17 posts
- DSpider
- 14 posts
Drop an “Attribute Randomize” node before the “Copy to Points” node and change the Attribute Name from “Cd” to “scale”. Then you'll have min-max values and you can drag the “Global Seed” slider (from the “Options” tab) until you're satisfied with the variation (and maybe not use min-max from 0 to 1 on all axes, but something like 0.5 to 1, which gives it a more subtle variation).
