RFE: turn off node auto arrange
   3461   1   1
Hi all,
So I have a large network.. jump back and forth adjust things, at some point I jump somehere to the beginning of the network and add a node.. and endup with a bunch of nodes that are spaced miles apart verticly. Houdini trys to make room for the new node that I've added but the auto arrange spaces those nodes really far apart. Only way to get back is to copy the added node.. undo till you get the original layout of the network and paste the node back and connect it yourself. It would be good if we can switch that auto-arrange off and have the new node just be added on top of other node.
thanks
Adam
Been reporting this behaviour for years… I hope it goes away too.
