Houdini crash when a QComboBox is inserted inside a QtreeWidget
   1862   2   1
Hello!
I am trying to create a Qt shelf tool for Houdini. This requires a QtreeWidget with 2 columns, the first showing just some text and the second containing a dropdown menu. Below is an image illustrating this:
The result above is what I am aiming at, and is exactly what I get when I execute my code in an standalone python shell or inside other DCC apps. Whenever I try to execute this code inside Houdini though (e.g. in a hython shell, from a shelf tool, from the python source window), Houdini crashes with the following messages:
Fatal error: Segmentation fault (sent by pid 0)
Crash log saved to /tmp/houdini_temp/crash.untitled.sgatto_31294_log.txt
Warning: Missing charsets in String to FontSet conversion
Below the code I am executing:
from PySide2 import QtCore, QtWidgets
class MyWidget(QtWidgets.QMainWindow):
    def __init__(self, parent=None, controller=None):
        super(MyWidget, self).__init__(parent)
        tree = QtWidgets.QTreeWidget()
        tree.setColumnCount(2)
        tree.headerItem().setText(0, "Column 1")
        tree.headerItem().setText(1, "Column 2")
        cell = QtWidgets.QComboBox()
        cell.addItems(['a','b','c'])
        item = QtWidgets.QTreeWidgetItem(tree)
        tree.setItemWidget(item, 1, cell)
        self.setCentralWidget(tree)
win = MyWidget()
win.show()
Commenting
is enough to make the snippet work inside Houdini, so the problem is clearly with the insertion of a ComboBox inside a QTreeWidgetItem.
Does anybody have any idea of why this is happening? Is this a bug?
Any suggestions on alternative ways to make this work would be greatly appreciated.
P.S. I already tried passing hou.qt.mainWindow() and hou.ui.mainQtWindow() as parent to MyWidget, and neither made any difference.
Edited by stefa-no - April 26, 2019 07:38:03
I would also like to add that if do no wrap the code inside a class and execute inside a Houdini's python shell, it works.
Here is the snippet to test it:
tree.show()
So adding a QComboBox to QTreeWidget is generally ok inside Houdini.
Ok I finally found the problem. To make the code work it's enough to change
to
cell = QtWidgets.QComboBox(parent=self)
or
cell = QtWidgets.QComboBox(parent=tree)
I still don't understand why it fails only inside Houdini and only when it is inside a class, but at least I'll leave the answer here if anybody will ever face a similar problem.
