Run Python Script AFTER HDA cooks nodes
   2710   2   0
I want to lock a node AFTER it is cooked - it is a convex hull node and it's wrapping points selected by the user. The problem is that “On created” module seems to run before enything gets evaluated.
How can one run a second script in the same HDA to do something AFTER?
Edited by dankray - May 12, 2019 08:58:41
untitled.hip (208.5 KB)
Edit_By_Container.hda (15.5 KB)
Locking node inside an HDA is pretty uncommon workflow.
Probably better and the more reliable way would be stashing (Stash SOP) inside editable subnetwork inside HDA or file cache if it should be shared.
Look how grooming HDAs worked in 16/16.5.
Thanks a lot, I ended up dropping another python SOP inside, which switched file cache sop from read to write.
Edited by dankray - May 12, 2019 11:08:16
