Can I do this in VOP and VEX? Or is it only for vectors?
I would like my distance function normalised like you can in the Falloff node.
Would appreciate your help.
Thank you.
Normalise a float value to 0 and 1? (Normalised distance?)
7803 2 0-
- OdFotan
- 192 posts
- Andr
- 899 posts
the function normalize() is a different kind of normalization, that produces unit vectors.
If I understand, what you need is the fit() function to fit your values in range 0-1.
To use that function you need to know the max and min of your distance values: you can use the attribute promote node which comes with some handy promotion methods (maximum and minimum).
Have a look at the project file.
hope that's what you're after
cheers
cheers
- Kareeem
- 100 posts
Andr
cheers
Thanks !!
