Rendering WhiteWater foam in Houdini 17 with Octane
   2118   0   0
Hi. Does anyone know how to render the new white water foam with Octane? I have the white water simulation setup and I can see the foamy particles in the viewport, but when I render I can't see the foam. I've tried applying my Octane foam material to the whitewater_import geomotry node, and all of the other geomotry nodes it creates when you click the whitewater button to create it, but it doesn't work. I was able to add my Octane water material to the actual fluid by adding the octane material to the fliptank_fluidinterior geomotry node render tab, but can't seem to get it to work like this with the foam. Any help would be much appreciated thx, am very noob sorry if this is a simple question. Attached my project file too.
whiteWaterRecovered.hiplc (3.1 MB)
