Hello everyone,
I was wandering how would I need to approach the need to trasnfer an attribute, say N, from a geometry to and identical one with an effector or some sort of object which position determines where the attribute is transfered.
When the transfer is from an A to a B object, the solution is a pretty straight farward classic Attribute Transfer Sop, but how about the A to B through C scenario?
I have found an easy fix with Sops: boolean substract a sphere form a grid A, copy the normal attribute from grid A to the product of the boolean then attribute trasfer from the product of the boolean to the B grid. Still this is very intricate and culd easily get superslow when dealing with more complex geomety, how could it be build inside Vops using some sort of geometry as bias/effector?
I attached an Hip with what i have so far
Thank you for yor time
Frankie
Custom AttTransfer With Effector in Vops
2121 3 1-
- ProceduralFrankie
- 76 posts
- Andr
- 899 posts
- adrianmeyerart
- 37 posts
Hey,
sounds like you could do this in a couple different ways.
If I understand right, you could approach it like this.
Build your own attrib transfer either in VEX or VOPs.
Just using pcopen / pcfilter approach.
Make your mask object a fog volume.
In your custom attrib transfer you can import the mask with volumsample.
Then multiply attrib transfer result by the volume value.
Edited by adrianmeyerart - July 19, 2019 03:01:51
- adrianmeyerart
- 37 posts
