rotate a flip pump
   3650   6   2
Hi
as the title suggests, how can i rotate a flip pump?
i can get the pump object to work, but as soon as i rotate it, the direction of the pump stays the same.
im using an wrangle to drive the vel from the normals.
i have a volume trail, and the normals are pointing in the correct direction.
iv uploaded a hip file if any of u guys can help.
it seems like it should work, but what am i missing. Relatively new into Houdini.
Kind regards
Harv
PS H17.5 apprentice version
Edited by dr_ron69 - July 18, 2019 18:18:52
01 pump-rotate-test 03.hipnc (2.1 MB)
for anyone else needing to know:
Atom on ODFORCE kindly helped me out
https://forums.odforce.net/topic/42985-rotate-flip-pump-source/ [forums.odforce.net]
Harv
This no longer works in H18
missing fields i wonder why
never mind found the solution
Hi
For future reference
What was the solution
I'm out of houdini currently and back onto 3ds max lol
Harv
i replace (the new H18)volumesource node with the good old sourcevolume…
i wonder why SESI change it and not being backward compatible and what changed….
patar
The fields are missing in 17 too just it doesn't break it in 17. The fields that it says are missing are actually there too so not sure why this doesn't work?.
