HDA error related to absolute paths
   3199   1   0
I have a file that works well but references a HDA that I created. However, when I go to type properties and “apply” or “accept”, I get the following error message:
The selected subnet has references to nodes outside the subnet, or has references that use absolute paths to operators inside the subnet. These references should be converted to relative internal references or this operator type may not work properly in other Hip files.
/obj/R_Hand/R_hand_bone_ctrl/constraints_path: constraints
I have gone into that node and there are no constraints. There is nothing I can delete or change. Where could I find the problem to fix it? Thanks.
I found the answer. I'm not sure how the corruption crept in, but I had to enable constraints and instead of deleting the constraints, I had to select “clear” and resave. It fixed it.
