I add used sub HDA to hdaprocessor/files for move files to job directory but I dont know how set it for use it when HDA processor run
I use relative paths for everything else.
I need run PDG on different paths because I run it on different server machines
HDA processor dependenci on move project to other directory
3493 6 0-
- X_H_N
- 31 posts
- brooke_sidefx
- 391 posts
- X_H_N
- 31 posts
- brooke_sidefx
- 391 posts
If you add the nested HDAs as file dependencies in the “File Dependencies” tab, it will copy the HDAs to the PDG temp directory, which gets added to the OTL scan path. Therefore, as long as any HDAs that the main HDA is dependent on are added as file dependencies, the asset should cook successfully.
Edited by brooke_sidefx - Aug. 16, 2019 10:57:09
- X_H_N
- 31 posts
- brooke_sidefx
- 391 posts
- X_H_N
- 31 posts
