Using OSM Import SOP I was able to import the OSM vector data.
For reuse on realtime engine I need them to be exported in ESRI Shapefiles .shp format.
I didn't find any tool useful for this work, does anyone have experience on this.
(Solved) Export OSM data in shapefiles format
3925 2 1-
- davide445
- 54 posts
- davide445
- 54 posts
- nedpatru_sped
- 3 posts
davide445
Solved: using QGIS I'm able to read osm file and export in shp format.
A pity can't be done in Houdini (at least I didn't find a node able to).
How do you get the the OSM file out of Houdini, though? What kind of export do you run from Houdini in order to generate a file that can be used inside QGIS?
