How to reference a custom attribute in a channel.
   3339   2   2
This questions might be basic. I'm trying to reference a custom attribute @speed inside a channel. But the value doesn't seems to be read, is in fact being interpreted as zero (which is not). If I reference it as f@speed, then I get an error. Is there a specific way to do this?
This is the way I'm referencing the attribute, but as I said it returns zero.
you might want to create a detail attribute and use it in parameter like this
@Time * `detail("/path/to/ref/node", "speed", 0)`
you can't use just an attribute, you have to specify the source of it (points, prims, detail, vertex)
Edited by anon_user_09389530 - Nov. 13, 2019 22:37:15
I contribute to the beauty of this world
https://houdininotes.ivanlarinin.com/ [houdininotes.ivanlarinin.com]
IL
Thanks, that is exactly what I needed. Thanks a lot.
