I cannot find the way to store/write integer value back to the attribute. For vectors we use vstore3 (ie, vstore3(value, idx, P)), what should I use for integers?
Store integer in OpenCL node
1902 2 1-
- perpen
- 60 posts
- anon_user_09389530
- 205 posts
As it's just a huge array of integers you can have access to the element of the array using this syntax.
Where idx is the current work item.
Make sure you have your parameters for readable/writeable turned on.
vstore3 is no more than
DIM could be any number depends on your dimension size, for vectors it's 3
yourattrib[idx] = value;
{ int block = idx*DIM; dataout[block] = datain.x; dataout[block+1] = datain.y; dataout[block+2] = datain.z; }
Edited by anon_user_09389530 - Dec. 24, 2019 20:34:00
I contribute to the beauty of this world
https://houdininotes.ivanlarinin.com/ [houdininotes.ivanlarinin.com]
- perpen
- 60 posts
