I've added a HdMyRendererPlugin_Viewport.ds file under $HOUDINI_PATH/soho/parameters following the example, and that doesn't help either. Is there some other magic I need to do?
#include "$HFS/houdini/soho/parameters/CommonMacros.ds"
name "my"
label "my"
parmtag { spare_opfilter "!!SHOP/PROPERTIES!!" }
parmtag { spare_classtags "render" }
parm {
name "max_progressions"
label "Max progressions"
type int
size 1
default { 4096 }
range { 1! 4096 }
parmtag { "spare_category" "Sampling" }
help "Maximum number of progressions to run"
// The "uiscope" tag is a space separated list of tokens which
// determines where the UI should be presented:
// - viewport: The display options dialog
// - toolbar: On the sidebar of the render view
parmtag { "uiscope" "viewport" }
parm {
name "max_path_length"
label "Max path length"
type int
size 1
default { 1024 }
range { 1! 1024 }
help "Maximum length of a path in edges"
