Export Alembic as a separate objects after Vellum sim
   1498   1   1
Newbie Question.
I understand is possible to export and separate an alembic by using “partition mode” by adding attributes which… I don't know where and how to setup in my node tree.
Scene: a cloth collides with a sphere and floor. Just need to export the cloth sim but when export happens all object come as one. I need them separated. Rop partition mode/attribute is grey out (may be because lack of attributes?) is there another easy way to achieve this?
I'd really appreciate your help.
You should be able to turn on “Build Hierarchy From Attribute”. Then add a prim string attribute called “path” and give each object a different value. ie: “cloth”, “ground”
