Vertex animation not working in Unity
   2061   3   0
Hi guys,
I made a fluid simulation in Houdini which I poly reduced a lot so I can import it later in a game.
The issue I am facing right now is that the exports don't want to be read in into Unity.
I followed the tutorial of Mike from SideFX here: https://vimeo.com/357836202/eb2c7c62be. [vimeo.com]
Even with this I still have a pink triangle cloud in Unity.
Does anybody know what the issue can be?
I also installed Houdini Engine in case that was needed, but nothing changed.
If someone can help me get a solution for this I would be very grateful!
Have a nice day,
Water_Splash_Reduced.zip (8.2 MB)
Okay so I am still trying to troubleshoot the issue, I noticed that when I export, I get the message “material doesn't exist” in the Houdini Console. So I tried to add a material on it, but even then I get the same message in the console.
Does a Fluid VAT need UV's in order to work properly?
Here is a video showing the settings and the setup of the vertex animation.
https://vimeo.com/416659149 [vimeo.com]
For some reason I can't figure out what the issue with this is.
Any help would be appreciated .
Edited by GenesisCry - May 9, 2020 10:03:33
Have you figured this out? I'm getting the same issue, just turns into a cloud of triangles, all my settings appear to be the same. I'm just animating noise from a Mountain node on a sphere.
