Particles: how to display points vs sprites ?
4178 4 0-
- k2msmith
- 7 posts
If I use the shelf tool “source particle emitter” on a selected Houdini shape such as a grid or torus, the particles generated will be displayed as points in the Scene View. If I use the same tool on a group of faces selected from a model, the default display of particles seems to automatically display large black squares representing sprites. Is there a way to change this rendering to render particles as with the grid or torus shapes ?
- N-G
- 213 posts
- k2msmith
- 7 posts
I put an attribdelete node in the source geometry tree (to delete the shop_materialpath attribute (which had a /mat/blinn material on it and it works. I guess I don't understand why source objects can't have materials on them if you don't want to use particle sprites, but maybe I don't fully understand the particle sprite/rendering mechanism in houdini yet.
- malexander
- 5293 posts
- k2msmith
- 7 posts
