Setting Required Inputs and Number of Inputs for HDA
   2036   0   0
Hey y'all!
So I have a multi-part question:
  1. Is there a way to set the required inputs for the HDA? I have made an HDA that has a minimum num of inputs of 2 and maximum of 11. If any 2 of the inputs are filled, the HDA bakes and it results in an error state that requires a UE restart. I would like to set two inputs as the required inputs, and the others are optional. Is this possible?
  2. Next, is there a way to hide inputs depending on a parameter from the HDA? This would fix the issue from above, and make the tool cleaner for when artists use it in UE.
Thanks!!
Jim Watson
Senior Technical Artist
Bend Studio - Sony Interactive Entertainment (SIE)
