Syntheyes to Houdini Issue.
   4058   4   0
I have tracked some footage in Syntheyes and exported to Houdini via script.
I get a drift on the trackers in Houdini. Pics to show drift in track circled in red.
I also exported the same track to After Effects and the track is solid, no drift.
Has anyone come across this issue? Or have any idea as to why this might be happening?
houdini 18.jpg (314.8 KB)
Hey Ralph,
The first thing I can think of is the fps settings.
Cheers
CYTE
Hey Cyte,
That was my first thought because it is 29.97fps, so I rendered it out in frames and ran it through Syntheyes again. Same problem.
R
I can think of two things that could be an issue (I haven't used Syntheyes, but I have successfully imported camera tracking from Blender into Houdini):
1. Is it possible that Syntheyes' first frame is 0 while in Houdini it's 1? So everything is offset by 1 frame?
2. 9 times out of 10, the main problem is the film back size which is incorrectly exported. Basically I would double check to make sure that both your film back (i.e. sensor size) as well as your lenses are matched to the Syntheyes ones.
>>Kays
It is the lens distortion that is applied in Syntheyes.
Thanks for the help.
R
