Problems with Mouse Event Handler when Duplicating Node ( As
   2020   1   1
In H18 when a node ( which type is user created digital asset ) is duplicated this happens:
Any Ideas?
Thanks in Advance !
The whole error message:
File “Mouse Event Handler”, line 19, in <module>
File “C:/PROGRA~1/SIDEEF~1/HOUDIN~1.348/houdini/python2.7libs\nodegraph.py”, line 99, in handleEvent
handler_coroutine.send(uievent)
File “C:/PROGRA~1/SIDEEF~1/HOUDIN~1.348/houdini/python2.7libs\nodegraph.py”, line 165, in handleEventCoroutine
pending_actions)
File “C:/PROGRA~1/SIDEEF~1/HOUDIN~1.348/houdini/python2.7libs\nodegraph.py”, line 720, in handleEvent
self.applyAdjustments(uievent)
File “C:/PROGRA~1/SIDEEF~1/HOUDIN~1.348/houdini/python2.7libs\nodegraph.py”, line 929, in applyAdjustments
connect_outputs_to_multi_inputs = False)
File “C:/PROGRA~1/SIDEEF~1/HOUDIN~1.348/houdini/python2.7libs\hou.py”, line 10017, in copyItems
return _hou.Node_copyItems(*args, **kwargs)
OperationFailed: The attempted operation failed.
Warning: Problem while synchronizing child node:
Warning: Too many elements found for parameter “/obj/sphere_object1/vdbPlacer_001/bound1 Bounding Type”.
Warning: Too many elements found for parameter “/obj/sphere_object1/vdbPlacer_001/bound2 Bounding Type”.
Any idea ?
Thanks !
