Sprite/Shader/Render Problem
   4964   4   0
Here is a file i'm working on with a train and i've put the train and smoke at the top of the network. I cannot get the particles to show up when i render. How do i apply the shader to the sprites so it shows up in the render? Sorry that i'm newer at this than most of you. It is in Houdini 7.
Thank you,
Cory
foranimationtrain2.hip (2.0 MB)
I can't check the scene without the images, but I've done a tutorial about sprite rendering that can be useful to you. You can read it in my web page in the tutorials section: http://www.miguelperezsenent.com/ [miguelperezsenent.com]
beautifull.
Yeah it was pretty simple to figure out what happened. I deleted the texture I needed and I needed to fiddle around with the route specified in the String field of the Attribcreate.
